Hi
I checked the old topic relevant with the fading pattern by image scatter.
However I still can not find problem with my stuff.
I already flow it to the surface and I want the top and bottom parts fading out and become a smooth surface.
I try your file however I don’t know how to use these code.
I think the file you give me build the surface by point but mine is extrude.
l have no idea to use your file to solve my problem.
Which output should go to the input for the PULL P? Because I haven’t use the surface divide, it will show red when I connect the out put P for plane surface to PULL P.
Hi
Sorry to make you confuse.
I try to connect the suggest component in my file but it not working.
So I want make the pattern part is smooth near the marking edge. I think there has some mistake on my file to connect the PULL POINT.
Thank you, very useful update and no need to some components, can you add option to flip mesh in Hexdivide, the mesh flipped unlike the original surface.
Thank you all come to discuss it.
For The problem of the lunchbox, I always delete it after bake because my work is not so much, but if there has some good way to claear it , I will try later.
there has so much example that need to check. I’m wondering that if I want both end become smooth surface, should I edit in range before the move component.
