Opening a file in R7 results in a graphical issue. The background color should be grey and NOT black!
Rotating the object or scaling the UI will undo this issue and bring back the original background color.
Peter
Hello - what file are you opening, a Rhino file, or some other format? Does any file do this or just some? Also, please run SystemInfo in Rhino and copy paste the results here.
Hi Pascal,
Opening a Rhino6 that was saved to Rhino7. So opening a Rhino7 file. No, not all file have this issue, it’s a specific file!
Rhino 7 SR2 2021-1-12 (Rhino 7, 7.2.21012.17002, Git hash:master @ b109c0eb42133053936614c484cb870a02a53b49)
License type: Commercial, build 2021-01-12
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.15.7 (Build 19H15) (Physical RAM: 1.9e+02Gb)
Mac Model Identifier: MacPro7,1
Language: en-GB (MacOS default)
AMD Radeon Pro Vega II OpenGL Engine (OpenGL ver:4.1 ATI-3.10.18)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 32 GB
Graphics: AMD Radeon Pro Vega II
Displays: BenQ SW321C (184dpi 2x)
Graphics processors
AMD Radeon Pro Vega II (32 GB)
BenQ SW321C (2560 x 1440 @ 60 Hz)
USB devices
Wacom Co.,Ltd.: Wacom Intuos Pro L
Apple Inc.: USB-Serial (0001)
iLok: iLok
Native Instruments: Komplete Audio 6 MK2
SMI Corporation: DataBar USB2.0
Apple: Headset
Apple Inc.: Apple T2 Controller
Bluetooth devices
Broadcom: Magic Trackpad 2
Broadcom: Magic Keyboard with Numeric Keypad
Broadcom: Magic Mouse 2
Third party kernel extensions
com.softraid.driver.SoftRAID (5.6.9) 58844C00-8FB7-3DE4-84CC-F023DAD09DC6
Third party plugins
/usr/lib/swift/libswiftFoundation.dylib
/Users/petergerritsen/Library/Application Support/McNeel/Rhinoceros/packages/7.0/AMDDenoiser/0.4.1/AMDDenoiser.Mac.rhp “AMDDenoiser.Mac” 1.0.0.0
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.2.21012.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.2.21012.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.2.21012.17002
Hello - can you get 7.3 and see if that makes any difference? You can set the update frequency in Preferences > General to ‘Service release candidate’.
It seems R7 7.4 has nailed this issue Pascal.
OK, good - thanks for the update.
