I’m experiencing jittery movements when orbiting around in perspective view. I’ve tried everything from installing new NVIDIA drivers to toggling “enhance pointer precision” in the mouse settings. Nothing is working, so I’m curious if anyone might know of a solution. Thank you in advance!
Here’s my system specs:
I’m running Rhino 7 trial version on a brand new Dell XPS 17 laptop with Windows 11
NVIDIA Corporation
NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2
OpenGL version: 4.6.0 NVIDIA 536.40
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2023
Driver Version: 31.0.15.3640
Z-Buffer depth: 24bits
Stencil depth: 8bits
Total Video Memory: 4 GB
Run SystemInfo and post the results. Also what do you mean by ‘jittery?’ The frame rate is not what you expect or it’s jumping around? The latter might be objects too far from the origin.
By jittery I mean that it looks like there is lag as there would be in a fpv video game. Changing the scale of my display to 100% in my display settings appears to significantly help to reduce the lag, but it doesn’t remove it entirely. Any ideas?
Run “Systeminfo” in Rhino and post the results, to start.
Rhino 7 SR30 2023-6-12 (Rhino 7, 7.30.23163.13001, Git hash:master @ f695e494df78377a81b2b95edb99c6067e324b33)
License type: Evaluation, build 2023-06-12
License details: Cloud Zoo
Expires on: 2023-10-03
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 12-21-2022 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Laptop GPU (NVidia) Memory: 4GB, Driver date: 6-23-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.40
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Z-Buffer depth: 24 bits
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.30.23163.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.30.23163.13001
Well nothing much seems wrong, other than a 4GB 3050 is kinda bare-minimum spec. At least it’s not integrated video! Is this at 4K resolution? What sorta file are we talking about?
