Hey, normally it’s sometimes for no reason in shaded view, now the curves are not displayed in one window in all views. Is this an NVidea driver bug? Occurs through all previous versions. Is there a certain setting to solve this? Thanks in advance! Hannes
Hi Hannes, if you work with the MAC Rhino version it is a known bug reported here. http://mcneel.myjetbrains.com/youtrack/issue/MR-2312
If that is not the case, could you upload an example file and a screen shot of your OpenGL settings (Rhino- Tools- Options- View- Open GL)?
I have had this problem for years…although I think it is only a V5 thing - I don’t recall it happening in V4
No one seems to be able to solve it…
Anyway, It’s a tricky one, since it doesn’t always happen.
As far as I can work out its something to do with the curves being projected onto the cplane. They will sometimes display as if they were using a dashed line type, sometimes not display at all until selected…
The workaround is simply to simply call “zoom all” and it usually comes right.
