.ghuser files does not run
Hello, I downloaded some files to use them in grasshopper, they are in .ghuser format and doesn’t seem to be working. I tried drag and drop a single ghuser file directly into grasshopper, nothing happens. Also tried droping the folder with all the ghusers files and appeared this
And tried opening grasshopper>File>Special folders>User Object Folder and neither that way.
Maybe ghuser files are not supported in rhino 6, I don’t know. Could someone help me please??
Hi Gutherbaum,
I had the same proble you need to drag the .ghuser fromat file into the folder UserObjects.
The following is the path:
File/Special Folders/Setting Folder/UserObjects
