On a nMP 2013, with Ghosted view settings previously customized from default, I see the following anomaly that was not in the prior versions. Happened with one existing file as well as a newly created file with just a simple box element. I upgraded from 5A751 and have not used the versions between. Have not had a chance to test other Mac models.
Different from how Ghosted view has always work in past (the ghosting) The color is “washed out” or “faded” when a file is opened, placed in ghosted view, or deselected.
Open file
It should look like this
If I select the object I get this
But then if I deselect the object it will “fade”
And if I rotate or update the view, without selecting the object, it reverts to “normal.”
Unless something has changed affecting my prior settings I have not grasped? Here are those setting:
Software information
Software versions
Rhinoceros version: 5.0 WIP (5A783w)
IronPython version: 5.1.2015.131
Language: en (MacOS default)
OS X version: Version 10.10.3 (Build 14D131)
Plug-ins
None
Third party kernel extensions
com.paragon-software.kext.VDMounter (526.1)
org.virtualbox.kext.VBoxDrv (4.3.12)
org.virtualbox.kext.VBoxUSB (4.3.12)
org.virtualbox.kext.VBoxNetFlt (4.3.12)
org.virtualbox.kext.VBoxNetAdp (4.3.12)
com.paloaltonetworks.kext.pangpd (1.0.0)
Hardware information
Computer hardware
Hardware model: MacPro6,1
Processor: Intel Xeon CPU E5-1680 v2 @ 3.00GHz
Memory: 32 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD FirePro D500 3072 MB
Memory: 3072 MB
Screen size: 2560 x 1600
Displays: Cinema HD (101dpi 1x)
USB devices
SanDisk: Extreme
OWC: Elite mini USB3
LaCie: Rugged USB3-FW
Apple Inc.: Bluetooth USB Host Controller
Bluetooth devices
Cambridge Silicon Radio: MX1000 Mouse
Broadcom: Apple Wireless Keyboard
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-1.32.20
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 0x
Mip map filtering: None
Anisotropic filtering: None
edited for typos…
