GH2 - Volume bug
Hi all -
First, wow - I hadn’t checked in to GH2 in a while. It is coming along nicely - really impressive. Love the fancy factoring in the text panel component, among many things. Exciting to think about all the things I don’t know about yet! :slight_smile:
I came across this weird thing (bug) with volume. Best way to explain it is this image:
I would expect the output of the “Volume” command, and the volume output of the “Volume Centroid” command, to be the same…
Cheers -
Tom
Hi Tom,
A simple test in 9.0.26012.12305 isn’t showing the issue. Can you post your geometry? Thanks
Hi Japhy -
I tried it again, and got the same result, but the caveat is that I hadn’t updated to the latest WIP. I was running 9.0.26006.14225, 2026-01-06.
I did an update (to 9.0.26013.12305, 2026-01-13), and the error has been fixed. Thanks for following up!
Cheers,
Tom.
