In previous Rhino7 versions it worked fine, but now “_VolumeCentroid” fails (attached file)
VolumeCentroidCalculationFails.3dm (62.2 KB)
Maybe I am doing something wrong but I do not think so
Regards
Joao
Regards
Joao
Hi Joao -
I tested your file here on a version of 7.5 and the current in-house 7.7 and that seems to work fine on both. Which version are you running (SystemInfo)?
@wim Does not work for me in Rhino 7 SR6 2021-4-13 (Rhino 7, 7.6.21103.13001
From the command line:
Compatibility test succeeded in 0.77s
Blocking plug-in RDK_EtoUI.
Blocking plug-in Orca3D.
Blocking plug-in 3Dconnexion 3D Mouse.
Successfully read file “C:\Users\David Cockey\Downloads\VolumeCentroidCalculationFails.3dm”
1 closed SubD added to selection.
Command: VolumeCentroid
Select solids for volume centroid calculation
Select solids for volume centroid calculation. Press Enter when done
Calculating volume centroid… Press Esc to cancel
Unable to calculate centroid.
Added: AreaCentroid does not work either.
Rhino 7 SR6 2021-4-13 (Rhino 7, 7.6.21103.13001, Git hash:master @ 3d8b63e6571eb752e8348635aa75ec08cf87e183)
License type: Commercial, build 2021-04-13
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 12Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) HD Graphics 4600 (Intel) Memory: 1GB, Driver date: 11-4-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 860M (NVidia) Memory: 2GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Users\David Cockey\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21103.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21103.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21103.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21103.13001
C:\Users\David Cockey\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\David Cockey\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2020.12.7.446\SectionTools.rhp “SectionTools”
Does not work in :
Rhino 7 SR6 2021-4-20 (Rhino 7, 7.6.21110.13001, Git hash:master @ 2e367bb5473238ebf7cfec4891ea72958ce57539)
License type: Commercial, build 2021-04-20
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Total Video Memory: 11 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21110.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21110.13001
Hi Wim
I am running SR6 and it does not work as in Dave’s case
License type: Educational, build 2021-04-20
License details: Stand-Alone
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 7.9Gb)
Primary display: Intel(R) HD Graphics Family (Intel) Memory: 1GB, Driver date: 3-8-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce 840M (NVidia) Memory: 2GB, Driver date: 12-18-2017 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 388.73
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 12-18-2017
Driver Version: 23.21.13.8873
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot6RhinoPlugin (0b79bf6d-9d2c-4c19-84ff-d015c84b0a6b)\1.1.0.0\KeyShot6RhinoPlugin\Rhino 5.0\x64\KeyShot6RhinoPlugin.rhp “KeyShot6RhinoPlugin” 1.1.0.0
Hi -
Does the command work on a regular NURBS box?
Yes, it works and places a point in the centroid as it should.
Same for me.
What if you mesh the SubD object? Does VolumeCentroid then work for you?
Also, does it work for other SubD objects?
What about a new SubD object in a new file?
(grasping at straws here…)
Created a simple SubD box using SubDBox SubDBoxDC01.3dm (2.4 MB)
VolumeCentroid, AreaCentroid, Volume, Area do not work with the SubD box. (They work with the ToNURBS version.) Command line results below.
[quote=“wim, post:9, topic:122819”]
[/quote]How do I mesh a SubD object?
Command: AreaCentroid
Select surfaces, polysurfaces, meshes or closed planar curves for area centroid calculation
Select surfaces, polysurfaces, meshes or closed planar curves for area centroid calculation. Press Enter when done
Calculating area centroid… Press Esc to cancel
Command: Volume
Select solids or solid meshes for volume calculation ( Units=ModelUnits )
Select solids or solid meshes for volume calculation. Press Enter when done ( Units=ModelUnits )
Calculating volume… Press Esc to cancel
Unable to calculate volume.
Command: Area
Select surfaces, polysurfaces, hatches, closed planar curves or polygon meshes for area calculation ( Units=ModelUnits )
Select surfaces, polysurfaces, hatches, closed planar curves or polygon meshes for area calculation. Press Enter when done ( Units=ModelUnits )
Calculating Area… Press Esc to cancel
Unable to calculate area.
