Hello all,
I have a closed polysurface but for some reason GH cannot calculate its volume and centroid. I tried cap command, in both Rhino and GH, but still doesn’t work. Any ideas or suggestion will be much appreciated.
LateralPanel.3dm (6.4 MB)
Hello all,
Hi Wim,
Thank you for your answer. The volume I am working with came from another volume with was half if this surface. So I rotated it and the join the volumes again, and then I subtracted the rounded eges. I guess I would need to clean the process somehow. I just have another question. How were you able to see that the surfaces were not matching appropriately? I tried to zoom in as much as I could and I was not able to see it.
Thank you again
Hi -
I simply ran Intersect on those two surfaces and only a short piece at the very top was found.
