I saw someone touched on this in Nov of 2016 but I thought I would ask with a couple alternatives.
At work we do a lot of scenic elements and wall structures. I’m making a definition to be able to enter the wall shape with curves or 4 points and have it spit out the sub framing and skins based on material size.
Is there a component you can publish to the remote control panel that you can either manually type in a user variable (numbers based on range) or have a drop down to select from?
If there currently isn’t a component available do you think it would be possible to make one using C# or Python?
Thanks
-Ryan
