I am trying to create ggSAP frame elements using the ggSAPCreateFrame component. However, I keep receiving an error that states “1. Solution exception: Request for generated beam has coincident node points and is ignored at node 37 55.9137311999884,0,19.8118984”. See below for an image.
Correct me if I am wrong, but this seems to be occurring because the beam highlighted in green shares a similar point to the beam that is circled in red. However, the component seemed to work fine with the beam elements that I have circled in blue. Those beams are also split in segments at the column joints. What would be the solution for an issue?
Thanks!
