I am trying to assign constraints to specific nodal points using the ggSAPConstraintLocal component. Here is how I have my script set up so far.
The points component contains all of the points highlighted in green as shown below.
The issue that I am encountering is that not all of the points that are highlighted in green as shown above shown that a constraint has been applied in SAP. See below for an example:
This point should have “Rigid Body Constraint” assigned to it. Upstream of my script I made should that any duplicate points were removed prior to performing this operation. Any ideas as to why this could be happening?
Thanks!
