Hi all,
I am trying to extract uvs of an object. The way I extract them is this:
ON_TextureMapping texture_map; ON_Xform localXform; const ON_MappingRef* pMR = obj->Attributes().m_rendering_attributes.MappingRef(uuidCurrentRenderingPlugIn); CRhinoTextureMappingTable& table = ::RhinoApp().ActiveDoc()->m_texture_mapping_table; if (pMR) { const int iCount = pMR->m_mapping_channels.Count(); if (pMR->m_mapping_channels.Count() > 0) { const ON_MappingChannel& mc = pMR->m_mapping_channels[0]; int iIndex = mc.m_mapping_index; localXform = mc.m_object_xform; texture_map= table[iIndex]; } } mesh->SetTextureCoordinates(texture_map, &localXform); for (int p = 0; p < mesh->m_V.Count(); p++) { ::RhinoApp().Print("%f , ",meshDup->m_T[p].x); ::RhinoApp().Print("%f \n ",meshDup->m_T[p].y); }
The problem is that if I change the texture mapping from the GUI (rotation, repetition, offset) the UVs do not change and they are always in a range [0,1]. I might have misunderstood but I expected to find the transformation applied onto the UVs. And however I do not know where to get these change made in the GUI.
Is there any way to get the correct uvs of an object?
Thanks in advance,
G.
