Could you be so kind to help me to understand which is the order for the selection of the Sliders when using Get Selected Objects? I’ve seen this is not the same with the order in which I’m selecting the sliders before to activate ‘Select’ command!
Thank you!
It’s the “document order,” which usually corresponds to the order they were created in, but you can manipulate by moving them up and down in the draw order (really!)
The back-most item will show up first (you will have to reselect.)
You can also sort items after the fact (e.g. by the Y coordinate of their pivot) if you want them in the visual order of top-to-bottom.
Thank you!
