Hey does anyone know how to create a solid geometry from this? or create the same sort of thing in another way.
Trying to make a leaf est solid, that’s completely angular.
Have been able to extrude the geometry flat and taper the thickness or heights of the vertices without bending it.
Thanks
think I found the solution to be using surface divide so it doesn’t sub-divide the surface when I move the points.
If anyone knows a better way all ears.
Thanks
i would create a mesh face using the vertices of the curve (3Dface), then triangulate it (TriangulateMesh) convert that to nurbs (ToNURBS).
You can also just patch manually by drawing triangular surfaces…
Thanks that works really well. Appreciate it.
