GEODESIC DOME Divide surfaces
1 INSIDE WOOD GRIDSHEEL (geodesic sphere).gh (18.4 KB)
Hello guys,
I received this script in my last post. It’s nearly working as I want it to. The only problem I still have is that I want the final result, not ass one poly surface. I want it to be many pieces that are like the red outline I marked in the image. In the end, it should still be the same form just in many of those pieces.
I would appreciate your help!
Till
This is your third thread on this subject, eh?
Yeah, Its kind of a big project I’m doing.
I just clicked download and install and then installed the used plugins.
1 INSIDE WOOD GRIDSHEEL (geodesic sphere)_re.gh (26.4 KB)
Branch colors cluster by @Joseph_Oster available here:
-Kevin
Yeah, but I learn more and have more fun without the plugins. Like the disabled pink group that shows some planar polygons - most of them are not planar.
I see that @kev.r has beaten me to it though. :sunglasses:
I started with code I posted to your thread six days ago:
At first I tried a C# cSwp1 thing from another thread but it was slow and left gaps (disabled gray group) so I resorted to the Clipper plugin to do an offset, then scaled and lofted to get hexagonal solids.
geodesic dome_2023Feb24a.gh (45.8 KB)
Thank you, Kevin! Perfect and simple solution!
Wow, Joseph thats actually very impressive without plugins.
I wandered around in the woods for awhile and didn’t clean up unused code.
geodesic dome_2023Feb24aa.gh (47.2 KB)
Its kinda complicated but works perfectly. How did you learn so much about grasshopper? You seam like an expert.
Thanks but I don’t consider myself an expert at Grasshopper. I’ve used it for nine years(?) and been active on this forum and its predecessor for eight years. I’ve read a lot of other peoples’ code, which is a great way to learn. I was a programmer in conventional languages for ~40+ years, with a penchant for detail (OCD?).
The code I posted here wasn’t perfect, though I fixed some things (below). I actually started with code from this post, not the reference I made earlier:
The current code is based on some observations of the dome geometry.
  • There are 720 triangular surfaces.
  • Disc and CullPt (white group) tells me that there are 362 unique points.
  • These points are the centers of the hexagons and pentagons.
  • So each of the 362 points has 5 or 6 nearby points around it.
I used Closest Points (‘N’ = 6, not 7) to get those nearby points but need a way to ignore one of them for the pentagons. I had used Smaller than 2 to cull them but that depends on model dimensions and would break if the dome were larger or smaller… So I’ve replaced Smaller with the purple group (below) to tell me if I should use only five or all six of the points.
The rest is details. Like sorting the 5 or 6 points AlongCrv (circles) to get them in proper sequence before connecting them with PLine, etc., etc.
Other facts I learned about the dome geometry:
  • There are 362 “polygons” - no surprise, same as the number of unique points.
  • Of those, there are 32 planar surfaces - 12 pentagons and 20 hexagons. All the rest are not planar.
geodesic dome_2023Feb25a.gh (44.2 KB)
P.S. I’m pleased and a little surprised that my sketchy purple group holds up when the ‘V Count’ slider value is reduced. Doing this breaks yesterday’s code.
I used Clipper because standard GH Offset Curve didn’t work correctly. Since then, I changed the way I derive the relevant planes so decided to check again, but no joy. Instead of Clipper I now use Scale to make an offset (inset) of the Pline curves, which works fine. No plugins at all now. :sunglasses:
geodesic dome_2023Feb25b.gh (42.3 KB)
Thank you for that detailed explanation. That really helps to understand the problem. Also achieving this all without plugins is quite insane. I wish I would be able to do that.
Thanks again
I explored several ways of deciding whether to use 5 or 6 of the closest points (purple group), including variance computed in Pyhon, but in the end used a simple method that compares the distance for the last point to the average distance of the first five points. The ratio (rounded) is 1 for hexagons (6 points) vs. 2 for pentagons (5 points). Works well, regardless of size.
geodesic dome_2023Feb26a.gh (45.6 KB)
