Generating Faces issue (Paneling Tools)
I use Paneling tools to create panels as below image.
I would like to create regular size panels as my goal but I ended up with a bit weird panelling.
Issue:
The reason of this problem is those diagonal faces.
Question:
Is there any way to delete those faces?
GH and Rhino files:
PanelingTools_Generate Faces issue.gh (34.6 KB) PanelingTools_Generate Faces issue.3dm (217.1 KB)
Thanks for your help in advance!
I find a solution the issue but it was not what I looking for.
I was looking for select the diagonal panel from one of Paneling Tools.
Is there any way to solve it?
Hi, the problem was that you were entering the surfaces as a tree instead of a list. If flatten the input, then you get the following result. I hope this helps.
Hi Rajaa Issa,
I really appreciate your advice and it can help me to understand about Data Tree.
