faceted wall.3dm (604.8 KB) I’m new to paneling tools, and have created a planar quad panel surface that I can’t select for some reason. I’ve tried toggling all of the prompts in the command bar for ‘Panel Planar Quads’ to no avail. I’ve also tried other paneling commands, and have now realized I can’t select any panels created with paneling tools (this wasn’t the case the last time I was using it a few days ago). Any suggestions would be much appreciated.
Thanks for looking into it.
Ok, I’ll try to re-word the question: I’m not able to select the panels I’ve made with any of the ‘paneling from grid’ commands. The panels are showing up on the screen, and I’m able to toggle the layer the panels are on, but I can’t select them with the cursor or select all. I’ve also used the command ‘sel bad objects’ and compulsively checked to make sure nothing is locked. The faces are performing as if they are locked when I go to select, but I am still able to modify the form with the pt grid points.
