I am using the SweepOneRail class in order to generate the surface above. There are two section curves (the thick black lines) and a rail curve (hidden here).
Instead of generating a NURBS, I would like to generate a mesh out of the same geometrical transformation.
Please note that I am not interested in post-rationalizing this surface but in generating the mesh upfront. So in other words, I would like to get only the planes - or intermediate cross-sections - from this geometrical transformation and not the surface. I would like to be able to play with the resolution of those, increase and decrease locally the density of the planes/cross-sections.
Besides the SweepOneRail class, I couldn’t find any interpolation method that takes into account two profile curves as well as a rail curve. I tried to browse a bit openNURBS for some source code, but this was unsuccessful.
Does anyone here might know how I could perform such operation, and indicate me the maths behind the SweepOneRail class in order to retrieve only the planes?
Unfortunately the two profile curves are oriented in a way that differs from the perpendicular frames of the rail curve.
I will try to tweak their orientation, but ultimately I think I would need to find a way to interpolate the two end frames along the rail curve, as SweepOneRail is actually doing…
Thanks for the help.
I finally managed to do what I initially wanted. The Rhino.Geometry.Curve.PerpendicularFrameAt() method actually worked.
I also had to interpolate the profiles on the XY plane and remap them onto the perpendicular frames of the input rail (see definition attached).
However - as the picture above illustrates - the final result doesn’t match perfectly what is generated with the SweepOneRail method (red surface). I would be interested to know where the difference is coming from, even if I am satisfied with the final mesh produced.
