Hi everybody,
this is my first post. I do develop software with VB and Rhinocommon and never found problems.
This is my first one.
Please look at the attached 3dm. I have to generate a sweep one rail where the closed curve is the rail and the triangle is the section moving along. Triangle is placed on curve’s start point.
If I try to create the sweep through Rhino interface, sweep is created and looks fine.
If I try to create the sweep using this VB code sweep fails and gets nothing back.
Could you please help me figuring where my mistake is? Here’s the basic 3dm.
Thank you so much
fabio
no_sweep.3dm (22.6 KB)
See if this doesn’t work any better.
Protected Overrides Function RunCommand(ByVal doc As RhinoDoc, ByVal mode As RunMode) As Result
Dim gr = New GetObject()
gr.SetCommandPrompt("Select rail")
gr.GeometryFilter = ObjectType.Curve
gr.SubObjectSelect = False
gr.Get()
If gr.CommandResult() <> Result.Success Then
Return gr.CommandResult()
End If
Dim railCurve As Curve = gr.Object(0).Curve()
If railCurve Is Nothing Then
Return Result.Failure
End If
Dim gs = New GetObject()
gs.SetCommandPrompt("Select cross section curve")
gs.GeometryFilter = ObjectType.Curve
gs.SubObjectSelect = False
gs.EnablePreSelect(False, True)
gs.DeselectAllBeforePostSelect = False
gs.Get()
If gs.CommandResult() <> Result.Success Then
Return gs.CommandResult()
End If
Dim shapeCurve As Curve = gs.Object(0).Curve()
If shapeCurve Is Nothing Then
End If
Dim breps = Brep.CreateFromSweep(railCurve, shapeCurve, False, doc.ModelAbsoluteTolerance)
For i As Integer = 0 To breps.Length - 1
doc.Objects.AddBrep(breps(i))
Next
doc.Views.Redraw()
Return Result.Success
End Function
Hi Dale,
thank you very much, your solution sorted it out
Cheers
fabio
