Generate Accurate 3D Mechanical Parts from Text Descriptions | Free Beta
Free Open Beta Now Available!
Works exactly as shown in this video :
Are you tired of spending hours creating 3D models for mechanical parts? Say hello to Text to CAD for free.
:rocket: Key Features:
  • Natural Language Input: Simply describe your mechanical part in plain English
  • AI-Powered Generation: Advanced AI trained on mechanical design principles
  • Rhinoceros Integration: Works within your familiar Rhino environment
  • Time-Saving: Drastically reduce the time spent on initial modeling
  • Accuracy: Designed specifically for mechanical parts and engineering applications. Very very accurate.
:light_bulb: How It Works:
  1. Open Rhinoceros
  2. Launch the Text to CAD plugin (command “MechanicalGenerator”)
  3. Type in your description (e.g., “A cylindrical gear with 20 teeth and a 5cm diameter”)
  4. Watch as your 3D model is generated in seconds!
:wrench: Perfect for:
  • Mechanical Eng.
  • Mechanical modellers
:free_button: Try It Now!
Download Text to CAD Beta https://www.food4rhino.com/en/app/genai-text-3d-model-mechanical-components-100-accurate
OR
Package Manager
Rhino8+
:loudspeaker: We’d Love to Hear from You!
Share your experience, suggestions, or report any issues.
Prompt example :
A flatbar 150x150 length 2000
A mounting plate {describe shape, holes, fillets}
A spring
A bolt #{size}
Any instruction you give will be followed, anything missing will be guessed.
It's very extremely accurate for generating 3d models of mechanical components.
Commercial contacts farouk.serragedine@gmail.com
I can train other models to generate geometry in your field contact me
Farouk
In the video it seems to create a mesh. Not very useful…
I can’t find it in the Package Manager:
@Marc
1.Currently It is generating a mesh that is true.
2.You have to wait for the Food4rhino team to approve it before download
I will consider mesh to nurbs conversion as I understand meshes might not work for everybody.
Farouk
Hi @farouk.serragedine
I think it would be important for mechanical parts to be created as surfaces directly.
Imagine you create a generic gear but you can’t snap to it’s center or draw a tangent line, it becomes useless.
Will be done on the next update.
This is mostly to gauge if there is interested in Mechanical Geometry generated automatically or not.
Just curious if NURBS has been incorporated and/or if this is still an active project?
-JW:
