Creating text for cut out/engraving in Rhino Cam
First time posting. If this is not quite the right place for this question recommendations for other forums are welcome!
I want to do the very simple act of creating a model of a sheet of plywood that will have a phrase cut out of it via Rhino Cam/CNC router. I can’t figure out how to do this after trying all sorts of things such as extrude curve, trim, edit curve etc. i don’t really understand what the text exists as, a surface? a curve? a mesh (and, i don’t really know yet what a mesh is)? and how do i describe it through rhino modelling so that the cam will recognize it in a way that it can be cut out?
any help or links would be great.
thanks!
Text can be what You want it to be. For cutting You need just a curves:
Thanks! Makes sense. Will give it a go today.
Daniel Coyle
Owner - Coyle LLC541-760-0774PO Box 2389 Corvallis, OR 97339
