Hi!
Is it possible to add full circular cross section? For rods , circular columns etc.
Thank you in advance @matttam @karamba3d !
Martin
Hi!
Martin
Yes definitely, you just need to use a circular hollow section and set the thickness to be the radius of the full section and it be recognised as a solid section,
Easy as pie! I just didn’t know if Karamba would take it that way.
did it work?
Because supposedly the thickness has to be half the diameter?
