nathanletwory
(Nathan 'jesterKing' Letwory)
July 14, 2018, 1:21pm
2
Nice, what render engine did you use?
akilli
(Ethan Gross)
July 14, 2018, 5:00pm
3
Thanks Nathan! I used Rhino Cycles, though there do seem to be a couple of artifacts in the lower left.
nathanletwory
July 14, 2018, 5:46pm
4
Cool. You probably can get rid of them by using Indirect Clamping, set it to 3 or maybe even a bit lower. You probably don’t need to set the direct clamping, but you can of course try.
Try this to clamp the over-bright white spots:
!_RhinoCycles_SetRenderOptions
_sample_clamp_indirect=3
_sample_clamp_direct=3
_Enter
It will also clamp down the brightest light from the HDRI, so you can set other values too, depending on the scene. Default is 0, so I have a button with both values, making it easy to swap back and forth.
akilli
(Ethan Gross)
July 15, 2018, 7:02am
5
Nathan, clamping definitely helps, the artifacts are gone. Rendering, unfortunately, is a field in itself. Thanks for the suggestion.
