FOAM FATAL ERROR in 3_SimpleWindAnalysis example of Eddy plugin
When I run the 3_SimpleWindAnalysis example I get the following message in the OpenFOAM prompt window:
Surface : “ground_perim.stl”
→ FOAM FATAL ERROR:
Cannnot read “C:/3_SimpleWindAnalysis/mesh/constant/triSurface/ground_perim.stl”
The simulation seems to run normally after that, though. Should I worry with the message?
Thanks in advance, and congratulations on the effort of making this tool.
Hi Aderson,
Thank you! I have never run into this but I will look into that for the next release.
Best,
Patrick
