I want to make a line connecting 2 points, see photo.
Now the connection goes from pt A to pt B, and I need to reverse it, so that the line will go from pt B to pt A.
I already tried to reverse the order of components, but it didn’t have any effect.
How can I do it?
Regards,
Yarden
Even if you can reverse the order of points, you will only create curves or lines with opposite directions.
But they will look all the same, right?
I need the lines I marked in red, to loft them.
The reason is that there will be different materiality for each surface.
Why don’t you use Flip Curve
Shift list, shift path, relative item?
Nobody can tell you without your file…
Lotus buoy_Meters.3dm (26.5 KB)
Lotus buoy.gh (28.4 KB)
HI,
sorry I am now attaching me file.
Thanks for the help.
for some reason, it only works in Rhino 6
Bingo!
Wow!
Thank you very much!
I have a follow up question:
I have this geometry/script that I’ve made with rotating elements. See photo.
I need these elements to be placed on the bottom lofted surface, and on that bottom only. See photo
How do I sort through the data?
Lotus buoy5.gh (43.9 KB)
moving elements.gh (14.4 KB)
GRASS_HELP.3dm (108.1 KB)
