I’m very new to Grasshopper so be gentle with me. This is a small part of a much larger problem I’m working on so I’m sure there will be many more questions to come.
I have three sequential points which I have made into a poly line. After exploding and trying to loft the subsequent two curves, I’m getting a strange twisted surface. I gather that it’s due to the sequence order of points in the second line. How do I flip the sequence?
That’s it! I thought I would be able to apply this to a series of curves in a list, but the flip function only seems to work on a singular curve. I can split off the curves that need flipping and re combine them in order to loft a number of connecting triangles.
Yes that’s it. Thank you both for your help. So with your approach Joseph, you used a single curve (isolated by the ‘list item’ node) to drive the direction of every other curve (within the ‘flip’ node)?
Thanks again. So good to have a supportive community out there, especially for us beginners.
