Find Text command - All layouts
2022-10-19T04:00:00Z
Hi all, I’m in the process of developing drawing packages that are consistent throughout. What I need is a way to change all of the text or callouts that exists in all my layouts that refer to a “building number” or “number code”. Can the “Find Text” command work on multiple layouts without having to manually select each layout? Is it possible that a script exists to accomplish this? Currently I need to run this command manually on every layout which takes a considerable amount of time considering the many pages I have.
Thanks!
That’s going to be problematic.
Generally, Rhino does not let you select objects you can’t see.
That’s why you have to manually march through the Layouts.
My guess is some file parsing script may be required.
You might be able to use text fields referring to document user text for this
