Hello All,
I am stuck with these self intersecting circles patterns. I want to do Square patterns equally all over the circle can you please help me to solve this problem?
Thanks Arni
Hello All,
Thanks Arni
Hi Arny,
you mean something like this?
You could cut all the circles with each other, then use Sweep2 to create surfaces, then extract isocurves from these surfaces:
What you mean by equally? if you mean the same dimensions this is impossible
Hi Daniel
I need exactly like that ! In grasshopper I can control UV size but it is only possible in rectangle shape patterns
if I am having hexagonal pattens instead of rectangular shapes in the circles. How can I control and have common hexogonal for both the circles where it intersects.
I tried to explain in the below image it is just a
quick sketch
If you have doubt please ask me
Thanks
Hi Kavehdadgar
Thanks for your effort and I have attached new image below . I need common sharing patterns at the intersection . I would like to make hexogonal shape but how can I make the honeycomb structure in the intersection surface ?
If you can help me it will be great
@Arni, see partial solution attached to get you started (needs pufferfish for Swap UV component and lunchbox for hexagon cells)
