Fillet and vertex removal failing
Here’s the file
4rhinoforums.gh (18.2 KB)
I’d want to accomplish 2 things:
The first, get all edges and fillet them by an x value, I can make it work on a base cube, but not on this brep, like so, but for every edge
Secondly, I’d like to remove all edges that are more flat, so 90,180,270, out
Doing somewhat like this
doesnt work quite well… they dont really need to be removed either way, I just don’t want flatness
for the first point I’d suggest to give a try to Multipipe
while about this:
what do you mean exactly with this?
I haven’t yet tried with multipipe, but with the previous one, I get those annoying straight pipes that I can’t get rid of
That’s my main issue, although elsewhere, I noticed other straight horizontal/vertical lines/pipes, which I would like more to be inclined
I tried with multipipe, works fine with the wireframe of a cube, but not with my target geometry…
as there are the after mentioned flat edges that give issues
most of the problems come up because Region and Voronoi3D want Boxes as region:
a Box is a box (nice sentence lol) while the Brep you are working with is not a box:
up to this point it’s good, you have removed from the random points all the ones that were generated outside your real Brep shape:
but in the next step, by non providing a Box that determines how big the Voronoi3D must be, the Component will generate a Voronoi that is just as big as the Bounding box of all the Points involved in the operation, which -of course- happens to be smaller than your initial Brep:
and when you do the Solid Intersection of the Voronoi cells with your initial Brep, the problem of having a Voronoi Box smaller than the initial Brep is still present:
when you input a non-box Brep into an input that wants a Box, GH will generate the bounding box of that brep for you, and use that bounding box to do whatever the component needed that input for:
so if you plug your initial Brep to the Box input of the Voronoi3D you solve the problem with just one wire:
all this long explanation was just to mention that probably all the straight edges that you would like to delete, are the edges of the Voronoi3D cells that overlap the initial Brep edges, similarly to this post (where I’d go with Laurent’s solution):
4rhinoforums_Re.gh (25.2 KB)
[edit] depending on the Populate3D seed you are using, there will probably be some locations in the Multipipe that appear like this:
that is because of some very short segments that create edges you might want to delete:
what I usually do is using Pufferfish Cull Duplicates because for some reason I really do like the Average feature… but that component can be swapped with remove Duplicate Points that comes with Kangaroo 2:
final result :+1:
4rhinoforums_Re2.gh (31.9 KB)
Thanks
about this step
it works only if I use a square like brep? like if I use anything that doesnt resemble a square it fails.
I can more or less construct other shapes with a collection of squares but it becomes pretty painfull
you can pass the Brep into a Bounding Box component first, then pass the bounding box you get to the Voronoi3D B input
