Voronoi is not smooth filleted
Hi, I wnat to create a voronoi but I want it to be smooth like the picture. has someone a good idea how to make this? And how do you also create a fillet on the initial edge? voronoi-15987.gh (221.8 KB) Tnx in advance
I’m not working with Dendro.
But, Multipipe does a good job on this if you provide good input curves.
I split and rebuilt your curves. Kangaroo can be used to eliminate short segments and adjust the end points around them. The short segments have to be removed, otherwise you get nodes with self intersections.
The resulting SubD can be edited manually and/or turned into a NURBS.
voronoi-15987_mrtn.gh (240.2 KB)
