Hello creators,
Once again, I need your help with a stubborn issue. I want to eliminate the edges of the polysurface that are interfering with my Voronoi lattice.
Is there a method to cull these edges before inputting them into the Dendro components? Any assistance would be greatly appreciated.
Please note that : the script is quite heavy , brep data internalized and disabled for comfortable opening and needs to be enabled
you can use something like Pull Point on the Lines Mid-Point to those internal edge curves you don’t want, and cull-out everything that is under a certain threshold distance you set:
Quite the same as @inno but I uses closest point on curve, then sort the distance, and if the shortest is too close, it is not 100% but not far.
I didn’t use the lines because you lost some precision and the tool will worse. I don’t really understand why you use this as you want some 3d smooth output!!!
And as you use points in Dendro I am not sure it is useful to filter curves by length or duplicate.
the two approaches of curve closest point and pull point are clever stuff !
as intermediate grasshopper user ( self-taught ) i found this community critical regarding learning grasshopper ! can’t thank you enough !
