I have a question about a file that I am working with right now. It is opening so incredibly slowly on my machine even when I am working on it from my SSD. Sometimes is takes as long as 5 minutes or more to open or will simply lock up and I have to close Rhino and start again. Is there somewhere to submit files for testing? Or a way to inspect it for why it is so slowly beyond the Audit command?
The file is only ~270Mb and I have had files over 1Gb that have not been as bad to use. It does make heavy use of block instances (which is the only real difference from my usual workflow), but I had set it up that way thinking that blocks are lighter in terms of memory usage.
The only other thing that I can think of is that there is a lot of imported GIS and AutoCAD linework that is perhaps causing problems. I have just purged the file, saved and reopened and it hasn’t helped. While opening, it shows Rhino using about 10% CPU and ~6Gb of ram.
Hi Tykom -
Blocks may be more efficient but only if they replace repeated objects - one definition for any number of instances. Not sure what you have here but that is a lot of definitions - is each of these representing a lot of objects? If not, there is no efficiency - on the contrary, display may slow right down since there are some complex calculations for knowing where to show the instances.
Most of the blocks are representing apartment types that are repeated and then nested into another block representing the building that they are a part of. The blocks of the buildings are usually repeated but there are a couple unique ones.
We are experiencing something similar recently as it’s taken one of our users ~15 minutes to open a file using Rhino 6 and license from the Zoo (also 6). Was there any updates from John, Pascal or Tykom on this?
