Rhino Audit
This file takes 10 min to open , two days ago takes only 2-3 mins. Something is making this file a lot slower and I am trying to troubleshoot it.
The file freezes usually when this message is showing
“2024.07.18 09:56:31.911 -07:00 [1] | INFO | GlobalLogLevel changed to Information”
When I use the “audit” command, it says “Audit found problems” and “2 block table errors detected.”
How do I address the 2 block table errors? and what problems did Audit found? is the 2 block table causing this?
we did bring in block objects from older files these 2 days.
Thank you
"Document Manifest:
Texture Mapping: 6864 active, 1 system.
Material: 169 active, 2 system.
Line Pattern: 6 active, 3 system.
Layer: 369 active, 1 system.
Group: 122 active.
TextStyle: none.
Annotation Style: 2 active, 12 system.
Light: 697 active.
Hatch Pattern: 9 active, 9 system.
Block: 158 active.
Model Geometry: 50914 active.
Total: 59310 model components. 28 system components.
m_instance_definition_table[29]->ObjectCount() = 0.
m_instance_definition_table[30]->ObjectCount() = 0.
Audit Summary:
0 object errors detected.
0 linetype table errors detected.
0 layer table errors detected.
0 font table errors detected.
0 annotation style table errors detected.
Table tally:
369 layers
158 instance definitions
2 annotation styles
0 fonts
697 rendering lights
6 linetypes
169 rendering materials
Object tally:
1880 normal objects
36551 locked objects
29 hidden objects
0 deleted objects (in undo buffer)
12454 block definition objects
0 reference normal objects
0 reference locked objects
0 reference hidden objects
0 reference block definition objects
Audit found problems.
*Update1
I deleted all the blocks, and i still get the “2 block table errors detected”
