FIle opens as curves and not objects
I opened a dwg file on rhino6 and the file opens as 20 000 curves when there should be objects.
Display modes don’t work and if I import parts of this file to another file it shows up in far location and is lost when trying to zoom extents.
I need the file to show up as 3d buildings as it does on another computer, what is to be done with my computer?
thank you.
Hi @muurahaiskuningatar,
Would it be possible for you to upload the file here, or privately using this link: https://www.rhino3d.com/upload?
We could then take a look.
-David
Hi, problem was solved, thank you for your concern. I will try and change my post to a solved case.
Laura
