Anybody have a Linetype for Fencing? Looks sort of like this :
I got that from a Vectorworks user. It comes in as just a block of crvs. So that’s another question – how to get Linetypes from other platforms if people are willing to share with you?
As far as I know lines in Rhino can only be continuous or dashed. This pattern could probably be made with a hatch pattern, but that requires you to turn lines into thin strips and will only work with orthogonal lines. If you are fine with multiple lines then this is fairly easy to script.
like this:
import scriptcontext as sc
def fenceCurve():
---x---x---x---x---x---x---
this script divides a curve by length and adds 'crosses' to it, grouped per curve / polyline
www.studiogijs.nl
curves = rs.GetObjects("select curves to change into fence-style",4, preselect=True)
if not curves:
return
s=sc.sticky['scale'] if sc.sticky.has_key('scale') else 20
scale = rs.GetReal("scale of the arrow curve", s, 5, 100)
if not scale:
return
sc.sticky['scale']=scale
rs.EnableRedraw(False)
for curve in curves:
lines=[]
if rs.CurveLength(curve)>scale:
pts = rs.DivideCurveLength(curve, scale)
for pt in pts:
t=rs.CurveClosestPoint(curve, pt)
vec = rs.CurveTangent(curve, t)
line = rs.AddLine(pt-vec*scale/10, pt+vec*scale/10)
rs.RotateObject(line, pt, 45)
lines.append(line)
line_copy = rs.RotateObject(line, pt, 90, copy=True)
lines.append(line_copy)
group = rs.AddGroup()
rs.AddObjectsToGroup(lines, group)
rs.AddObjectsToGroup(curve, group)
rs.SelectObjects(lines)
rs.SelectObjects(curves)
rs.EnableRedraw(True)
fenceCurve()
Hi Alan - we have this request on the list as RH-29232 and I’ve added this thread to it.
@Gijs do you think you could pep that py snake up a bit to create a partially hatched line, or at least a double curve with periodic segments that i can hatch it myself?
something like that
i created a topic not long ago about this.
@wim can you add this sample to the wish tracker?
Done!
Thanks all. I haven’t gone into GH as of yet. But will check out those Py scripts.
Thanks again
nice one, thanks for the tease
glad to test it once its ready!
Hi! This is very cool! I´ve just tried it, and it seems that I can´t scale the symbols larger than 100 units. Is there a chance to dismiss this restriction?
Cheers,
Petr!
sure thing:
change it there
Great! I´ll try that
Thanks @Gijs
Awesome Gijs!
@mcarch in Rhino 9 WIP a new feature has been added that you may want to check out:
Awesome, I’ve just downloaded rh9wip & will definitely check it out . . . right now, having an issue with hatch patterns in section styles of referenced blocks . . . ;( . . . but I’ll check it out for sure. Cheers!
