[Feature Request] - Rhino 8 - Bake Content - "Bake Groups" Option
I would like to request the ability for the Bake Content component in Rhino 8 GH to have an option to bake the Content to Rhino groups based on their data tree structure or accept the groups node as a viable content connection for the bake component.
Example:
1000 curves
Data tree structure:
{0} - 350 curves
{1} - 200 curves
{2} - 450 curves
If “Bake Groups”:
Group 01 - 350 curves grouped with new group id generated
Group 02 - 200 curves grouped with new group id generated
Group 03 - 450 curves grouped with new group id generated
Current State (Group is not a valid model geometry.):
@AndyPayne do you have any current plans for potentially supporting this?
Groups likely wont be possible. However, we do have some ideas as to how you can bake content “as a batch” with a specific ID. Anyway, we do have some ideas on how you might bake only certain geometry and have it tagged in a specific way… but we’re still working on this idea and I don’t know exactly when it will be ready for release.
Hi @AndyPayne ,
Thanks for the info, sounds good! I don’t need the baked geometry to be grouped often but there are certain use cases where it would be critical.
I think for now as a workaround, I’ll create a python node that references the GUIDs in each branch path of the Bake Content C input and groups them in Rhino after the bake content component has baked them.
I think Elefront 5 added a bake to groups feature on their node and I’m curious how that functions, not sure what methods were used.
Anyways, looking forward to seeing what you all come up with,
Thanks!
I used the Elefront bake to group feature quite often but what I never liked is that the group name was in the format Group + running number. In my case groups would combine geometry from different layers. A script to group objects based on a user attribute could be another option.
