The default for EXPORT is to Rhino and to the same file name.
I wish there were as CANCEL button when get you the dialog saying that you are about to overwrite.
Hi @miano I do get that replace warning when exporting, can you send me _SystemInfo?
There is no simple cancel button. I have to do “revert” which takes several minutes.
Rhino 7 SR24 2022-11-4 (Rhino 7, 7.24.22308.15002, Git hash:master @ cb2ad12922ceb989b185972675bb705a00abb97d)
License type: Commercial, build 2022-11-04
License details: Cloud Zoo
Apple macOS Version 12.6.1 (Build 21G217) (Physical RAM: 64Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,2
Language: en-US (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 48 GB
Graphics: Apple M1 Max
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.24.22308.15002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.24.22308.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.24.22308.15002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.24.22308.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.24.22308.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.24.22308.15002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.24.22308.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.24.22308.15002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.24.22308.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.24.22308.15002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.24.22308.15002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.24.22308.1002
I think this addresses that problem -
RH-70327 Export: Leave out the file name
Does that make sense with wjhat you are asking for?
I think I must be seeing a bug. After restarting, I am getting “Cancel/Replace.” In actual day-to-day operation I am seeing “Overwrite/Revert.”
This could well be an Apple Rosetta thing.
That is indeed a severe and annoying issue. All this happens just on your single MacBook is that correct? Are all local files (on your Mac) or are you working on a network drive? Are the files being synchronized to a cloud drive in the background? To solve this we need as much info as possible.
I will have to check on that. I work locally sometimes and network drive sometimes. There should not be a cloud drive.
thanks, I believe by default, Mac will synch files from desktop to iCloud, so also keep an eye on that.
