What I want to do is I want to transfer my curtain panel block to the Revit as a family.
I see that I don’t get a warning in Grasshopper, but I can’t see any object in Revit.
I can’t figure out what the problem is. I would be grateful if you could take the time to help me.
Note that you’ll want to have these oriented the same way as Revit Family Template orients its geometry. Yours is laying Flat on the XY, you’ll want to stand this up so it comes in oriented correctly.
Tranferring to Revit family from Rhino block is quite promising! I am just wondering if some parameters in Gh associated to it is loaded as as a parameters of the family? in case someone wants to adjust the parameters with going to Rhino/gh or RIR? Thanks.
It sounds like something might be off in the transfer process. Here are a few points I got from my web search, hope these help.
Make sure the object is actually visible in your Revit view. Sometimes it’s placed on a different workset or hidden from view.
Double-check that the Grasshopper definition is correctly setting the object as a Revit family, and it’s being created in the right category.
Ensure the units in Grasshopper match Revit’s. If there’s a scale mismatch, the object might be too small or too large to see.
Make sure Rhino.Inside.Revit is properly linked and working. A restart of both Rhino and Revit can sometimes help refresh the connection.
Verify that the object is placed in the right location in Revit. It could be getting placed too far from the origin or in a view where it’s not visible.
