I recently discovered that I can extrude using the dot on the Gumball arrows. However, the resulting extrusion is not a capped solid. Can that option be set?
That answers it. Thanks.
And would be possible extrude closed curve as capped solid? E.t. with ctrl+shift or something similar? Would be greate and powerfull workflow…
