Extrude surfaces in both directions
I wanted to extrude a couple of surfaces like the following photo.
However, I failed to do it. What I get is this.
Can anyone help me?
test.gh (7.8 KB)
Perhaps you should do Offset Surface instead of extrude, with Solid option ON (YES) or whatever it was.
@ivelin.peychev. thank you
Still one problem. the corners are not extruded.
Capture4
You won’t be able to do that because it is a polysurface and not a single surface. Instead extend either the smaller surface(solid) both ways by the thickness, or the longer solids in direction of the smaller one. Then use boolean union (SolidUnion)
A workaround…
test_re_v1.gh (11.7 KB)
I was trying to solve it without Rhino in front of me :slight_smile:
I have model thing strip in surfaces and I want to put a thickness inside direction. I don’t have grasshopper, I am using Rhino7. purpose is to 3D print. If I extrude surface corners don’t get extrude or it overlap.
If you’re using Rhino 7, you surely have no choice but to have the grasshopper feature. :face_with_raised_eyebrow:
Hi, thanks for getting back. I just download your GH script and try to apply for my model. how can I pick the surfaces in my rhino model and apply to your script.
If you are an absolute beginner to GH, it’s a good idea to learn some basics first.
https://www.youtube.com/results?search_query=grasshopper+rhino+tutorial+beginner+
This is the file I would like to add a thickness (1mm) in inside direction. Purpose is to 3D print.Chine.3dm (1.7 MB)
Will you able to help me out. I just want to put a thickness to this surfaces inside direction. Purpose is to 3D print giving a thickness (1mm).
Chine.3dm (1.7 MB)
Hi - I don’t see how this is related to Grasshopper at all. Also see https://discourse.mcneel.com/t/add-thickness/.
