Extrude closed curve generate open polysurface NOT closed extrusion
Hi all,
My model has many closed planar curves, when I select all curves and extrude them, I got some open polysurfaces and some closed extrusions. I do not understand why I got open polysurfaces when the option “Solid = Yes” was selected.
The command that I used to extrude curves is “ExtrudeCrv”
Any idea how to fix this problem is highly appreciated.
Thanks,
Please post a 3dm file
test-1.3dm (750.9 KB)
here you go
Hello- not all of the curves are quite planar. Use SelPlanarCrv to see which ones are. User SetPt in Z only to flatten the non planar ones.
Do planar curves mean that they all at the same elevation (z = 0 for example)?
Thanks a lot Pascal. you are right, not all of them are planar. I imported the file and did not check if the curves are planar or not. My mistake. Thanks again.
