Hi, I have been dealing with some complex curves which I wanted to close and extrude into a poly surface, after several attemps I made a closed surface and manually splitted the surface with all the volumes in the hope that afterward, I would be able to extrude the surface. Sadly this is not the case, would someone be my hero and look at the file and see if they can resolve the problem?
Hi - What goes wrong when extruding?
It seems to work here but I imagine that it might be possible that your computer needs some time to deal with this…
Hi @wim, Thanks for looking at the file, when I extrude it seems to have problems becoming a solid file. If I would try to cap it now, it would take a while and return with an error. Thats why I was trying to find the root of the problem… Does your extrusion close itself? And if so would you mind sharing it in this dropbox folder or via another route? (The file is to big to upload via the forum).
Hi @davidcockey, thanks for looking at the file. I was using the curves in the hope to generate a surface that would be extrude-able into a solid. After initial trials with the curves I tried the surface but neither have produced the goal of a solid.
Hi @pascal, the problem is that the curves are closed, but they do not result into a closed solid or planer surface. The complexity of the curves is probably preventing to make it a solid. Please look at the file and see if by some reason it does work when you type in the command
