When I extrude the curve in the attached file with ‘split at tangents = yes’ the result is split at only 3 of 4 tangent intersections.
Version 6 SR13
(6.13.19035.17431, 2/4/2019)
cant split when extruding.3dm (563.1 KB)
Version 6 SR13
Hi Peter - I get that from Gumball extrude and not from ExtrudeCrv
- is that what you see?
Maybe I’m misunderstanding your reply, but if I use gumball extrude, the part is split as expected (as if splitattangents=yes), but when I use extrudecrv with splitattangents=yes, the result is split at just 3 of the 4 tangent points.
