Hi everyone,
I don’t know if this is the right place to ask this question, so moderators can proceed with this thread as they see fit.
When you use #ArchiCAD Grasshopper Live connection, you can access the different library part parameters from the “Object Setting Component”, the bad part is that you when you use the “Object Deconstruct Component” you can’t access the object’s parameters nor their values.
My aim is that I can access those values so that I can inject them with “Object’s Properties Settings” component.
And for that I need the basic script in (#python, or #ghpython, or #csharp, or #vbscript ) that can just see those values in Grasshopper …
This same question is also posted in ArchiCAD-Talk since I think that the answer will benefit the programs users, here is the link
