ExtendSrf - result is bad object
ExtendSrf this untrimmed, three side surface. Result is a bad object.
ExtendSrfBadObjectDC01.3dm (1.9 MB)
Rhino 8 SR7 2024-4-10 (Rhino 8, 8.7.24101.10001, Git hash:master @ 2b50f55c58918e10b4e2d13323128fce6021b72c)
License type: Commercial, build 2024-04-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9232.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2023
Driver Version: 31.0.15.4633
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Cyberstrak\R8\CS_ModelingPlugIn.rhp “Cyberstrak Modeling PlugIn”
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24101.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24101.10001
Added: I confirmed Cyberstrak is not the cause. I reloaded Rhino without Cyberstrak enabled and the result was the same.
thanks @davidcockey
RH-81507 ExtendSrf results in bad surface
I wasn’t able to get a bad surface using 8.5.24072.13001, 2024-03-12.
There are some changes in the 8.7 branch due to other bugs and this might be a negative side effect of it.
