Extend surface command acts weird in rhino 8
I have been creating versions of this object since rhino 5. Now this command works with this surface maybe 60% of times. For some other surface it might work every time.
With this surface of this object it may help if I make copy of the surface or just execute command several times.
Original surface is about 8mm wide and I´m trying to extend it 4mm (since rhino 5 I have done that 4mm so that I´we been doin twice 2mm extencion.)
Last two picture are same object, grey surface has been copied to different layer and the extend surfece 2mm. With out copying it did not do anything or did negative extension and with copied surface it created one in second picture.
Hi Atte -
Please provide both the output from the Rhino SystemInfo command and a 3dm file that we can use to troubleshoot.
Rhino 8 SR14 2024-12-10 (Rhino 8, 8.14.24345.15001, Git hash:master @ cdb74b46090a23fe242c51b288886f76467a741b)
License type: Commercial, build 2024-12-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-13-2023 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P620 (NVidia) Memory: 4GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\export_STL.rhp “STL Export”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.14.24345.15001
C:\Users\atteo\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.14.24345.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.14.24345.15001
You might consider updating your video drivers and Rhino.
Current Rhino release version is 8.15.
If it still acts weird, then at least McNeel will know you are talking about an up-to-date installation.
Thanks for this tip. I updated drivers and rhino. Issue remains.
Extend issue_2.3dm (542.7 KB)
this looks like a horrible and unnecessary dense surface.
_extendSrf fails here as well (8.16 on a mac)
_untrimAll
Keeptrims = yes
will show the underlaying surface and the trim-curves (blue)
the first
_offsetCrvOnSrf
8mm
the second offset is
30mm
I recommend the following workflow
_untrimAll (keep trims), _offsetCrvOnSrf _trim
instead of extendSrf.
There where some issues with extendSrf.
One is fixed in the current service release candidate.
ok - but i tested at least on a mac and it does not do the job as you asked - see above.
EDIT:
_extendSrf - click the edge, enter -8 (MINUS EIGHT) works here.
and
_untrimAll (keepTrims)
_dir (flip) the trim curves
_trim
_exendSrf 8 (without Minus) does the job as well.
did you try -8 ? does it work
kind regards - tom
Thanks for this. This might be a better way to do same thing. Still I wonder how extend surface use to work well in similar cases.
Btw: problem surface is about 30% more dense in sample file than it is normal case. It some times helps when density is raised. Some times not.
