HI
I am driven by need to “extend” below subd srf just 1 mm all around by maintaining original directions shown by the arrows
Does anyone know if there is a command or a method to do this ?
thanks
20210304 SUB D SRF.3dm (540.7 KB)
HI
thanks
@pascal
… and if the extend is not a tangential, but perpendicular row of quads (like _fin for surfaces) ?
_offsetSubD will do it somehow, but i get to much stuff and deleting is nasty.
(still missing _splitDisJointSubDs…)
and gumball scale with cmd… (but not really perpendicular)
any idea ?
thanks a lot Pascal , your suggestion was the way to go to allow me quick editing
only a few precisations :
1-I have used “across” option for direction not “along”
2- could not manage to get it done after inserting edge loop. ( actually to handle edge position is very tricky ) , i was able to slide only original edge , tought i had to try a few times until i got the extension to an acceptable level.
BTW the sliding behavior is very unconsistant and hard to handle …or maybe i am not handling it right
Is there some trick / shortcut to shift edge more precisely ?
thanks
Hi @cloudsvisitor77
I might be misunderstading what you are asking, but isn’t this exatly what ExtrudeSubD does when the Basis=UVN and Direction=V?
yess Jakob !!!
i managed to do it with slide edge as suggested by Pascal but this is exactly what i was looking for
thanks a lot
