2d offset edge of SubD for new faces
Hi, I would like to add new faces to my subD, like indicated by these yellow lines, like a 2D offset
how do I do this ?
Best
Andreas
Here are 2 ways to do it:
  1. Use the edge of the existing subd as the rail for a Sweep 1 Rail.
  2. (this is weirder) - extrude the edge of the subd up, then use Offset SubD with Solid=yes option, then delete anything you don’t want to keep.
There is certainly the need for a tool to do this directly, though.
thanks Peter, I will try it out…
Example:
Try ExtrudeSubD using that edge loop, Basis = UVN, Direction = V
Example:
thank you guys , it is really appreciated, nice video Inju ! best Forum ever!
