Extend surface by negative value not working on simple surface R7(SR13)
Simple planar 1 degree square surface. When I run the ExtendSrf command and type in “-10” + Enter (after selecting an edge) nothing happens. I can click and drag the edge in a negative direction but cannot enter an exact value via the command line. R6 (SR35) works as I expect it to.
Screen capture links and 3dm file below:
R7 ExtendSrf - Capture
R6 ExtendSrf - Capture
2022-01-11 ExtendSrf Negative.3dm (2.6 MB)
Hi Paul - I see that. thanks.
RH-66949 ExtendSrf: negative values fail
RH-66949 is fixed in the latest WIP
Does not appear fixed to me when tested with this simple surface:
ExtendSrfTest.3dm (1.6 MB)
I see the same behavior as originally reported:
Rhino 7 SR19 2022-5-17 (Rhino 7, 7.19.22137.07001, Git hash:master @ 3ae9a3803ff1583b53c0ef27b6860e06ef2d363a)
License type: Commercial, build 2022-05-17
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 4-20-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-20-2022
Driver Version: 30.0.15.1259
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.22.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.19.22137.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.19.22137.7001
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.21.831\SectionTools.rhp “SectionTools”
This fix is in Rhino 8 WIP right now; not Rhino 7.
@brian We could really use the fix in Rhino 7. Is that possible?
We don’t make fixes that could make things worse in the current stable version. But only @rajaa can tell us how big a change this was and whether it feels safe to put in Rhino 7. Also, Rhino 8 WIP is available to you now, so you can take advantage of this (and may other) improvements. See Welcome to Serengeti for details.
This might be a safe change to make the change in 7.
@carlRTC Please test at the WIP to make sure it did not break anything and that it is working as expected, and then we can look into populating to 7.
@rajaa, I just downloaded the WIP and ran the ExtendSrf command with a negative value, and it appears to work perfectly!
Great, please make sure we didn’t break anything else. Thanks
